over a range of vehicles so wouldn't consider myself an expert on what might or might not apply for you).
Best colour too.... I assume its the same pearlescent white as mine?
Yep like a pearlescent white it is, beauitiful colour or it will be once I've finished with it hahaha. Yep 100% look so much more expensive from the outside than the VW's imho... just 24 hours until pickupNiiiceBest colour too.... I assume its the same pearlescent white as mine?
Just go back last night from an overnight in Ogwen Valley, had people asking about the van again, which happens a fair bit. So much better looking than the VWs
Reminded me I need to get my underseal done before winter!
And yeah, I'll be blasting this whole thing off this week and then Lanoguarding the whole underside of it pal... use Lanoguard it's the best trust me!When I was looking at these some were claiming 11!Nice looking camper! What's the mpg like?![]()
I've just got 350 miles off a tank, so around 22mpg, on a motorway run. I don't use it for commuting obviously, but it's not too bad cruising at 60.When I was looking at these some were claiming 11!![]()
I've been looking at the Nissan Elgrand, the 3.5 variant is the same engine as used in the 350z!
Yeah I originally was looking for a bongo BUT just too small, plus overheating and rust problems now... just didn't click where'as this thing it bigger, more reliable, ZERO rust etc... I mean it's Toyota.. it's built properly... so went for this plus I think they actually look for an MPV very nice... really nice infact especially once I've slapped some decent wheels on this weekLove it. Always a fan of imports and vans
Ive been eyeballing vans like these but most of them are a bit too small so think ill be going Hiace Grandcabin or similar.
These seem to be replacing the Bongo as the camper of choice since the Bongos are getting on a bit
Pick up in half an hour... I never thought I'd be exciuted over an MPV hahahaThink they'd put a new battery on, it's been cleaned but does look newish. As for AC, yeah had it on yesterday driving home in 30C and it was ice cold. Filter done and changed, the only thing I need to look at is the cambelt... there is no record of this being done so... it must've been done but not willing to take the chance so it'll be coming off!Nice - (new/cleaned?) Battery seems close to the engine - do we get to hear it's V6 goodness.
In the current heat ... does the A/C/hvac need a recharge, or filters.
I can't mate they look so bad and I'm not refurbing those, they're diamond cut as well so, end up just looking gash anyway... OFF OFF OFFThe new alloys do look good. But in all hoesty I'd be keeping the originals on there. You may be driving up some rough places to get to campsites so I'd rather scrape the cheap wheels than put pretty new alloys on it. You'll also quickly get tired of cleaning spoked alloys on a vehicle that's going to get pretty dirty.
