Hey guys
I was hoping for a bit of advice on things I could try with my card before giving up on it.
Zotac 1080 amp extreme. Didnt use it for a couple of years as I was moving house, stuck in DIY hell etc.
Fired the PC up and the system seemed really slow. It was an X370 board so in need of an upgrade anyway so went for a X570 board, and on installing windows all seems well, with the Nvidia driver from 2020 that windows installs for you - but as soon as you install a newer Geforce driver the system starts running like an absolute dog - 5 mins to open task manager etc.
Tried everything, came to the conclusion maybe some sort of incompatability with the new motherboard - changed the board to a B550 and exactly the same thing.
So it has to be the GPU.
I've tried setting windows power to maximum performance, and nvidia control panel to prefer performance, no change.
Just wondered if anyone could suggest anything worth trying that might tell me if the card is dying? Is it worth taking it apart, redoing heatsyncs, anything like that?
Any suggestions gratefully received!
