So how's everyone's temps doing?
No gaming for me the last few days as its to hot in the room even with the PC off. The pool is seeing plenty of action though.
Despite room being 29+, PC has stayed mostly the same under load.
GPU in mid-60s, CPU in mid-70s.
Fan speed up ever so slightly, so GPU usually sits at 1050rpm~ now it 100-150rpm higher at or just under 1200.
Same for CPU.
Played a few hours of Hitman 3, and it was me that was suffering from the heat more than the PC :P
Main PC is upstairs with a desktop orientation rather than a tower still staying below 70C on both the CPU & GPU but the GPU fans are definitely up a fair amount. CPU AIO was fine but water temps were almost 50C which is quite a bit higher than normal.
I keep the windows and blackout blinds closed on the hot side of the house during the day which helps as it's hotter outside. The temp was getting quite unpleasant last night upstairs so I swapped to the 2nd PC downstairs plugged in to the C1 OLED. With a fan blowing across me and the gaming tower I was actually quite comfortable.
Today a little better but the AC is on and taking the edge off!
Weather is certainly great for testing an overclock :D
Imagine this was common with AC on and GPU giving out +300w with increasing energy prices
Don't have AC but if it was common it would have to be considered, currently the room the pc is in is 35c that's without it on
Pretty ballsy to run at those temps constantly, i take its a 6900xt/6950xt judging by the clock speed?
Nah it's usually under 90 which is fine, like I said it's good to run to check how solid the o/c is. It's a 6750XT Red Devil but it has to be noted am running a pretty quiet fan profile too.
Oh wow!! I never knew the 6750xt could run that kind of gpu clock! That's nuts!
Honestly, not really budged much apart from 1/2C on the CPU/GPU that I've noticed.
The NR200 doing an admirable job of keeping everything cool :)
Doesn't your room get much hotter though? Mine does which is why I will not do so again until this evening at the earliest.
Within spec, anything under 110c is a-okay for the junction temp which is the hottest part of the core.
That said, I prefer lower too. My 3090 FE memory temps were always around 104c too and that is also supposedly in spec also.
Generally speaking I don't game at all over the summer months (June - August). Living in the South of England and only using VR it's just too hot!
Ambient is 33.9ºC
Water temp is pushing 37ºC and 5960X o/c to 4.5 is at 58ºC at idle, with fans at 40%.
Not going to try gaming, as the room would just absolutely bake - I'm sure the PC would be alright, but *I'd* likely die!!
