3060ti 2fan vs 3080ti 3 fan temps
19 Nov 2010
Anyone know how the temps would compare?
I have the smaller ASUS dual 3060ti mini (2 fans)
I’m wondering if I put a full size 3080ti - 3fans (will have to check the dimensions first to make sure it fits) what would the temp difference be? Higher, lower or same?
Currently getting 70c gpu on full load.
The larger fans will move more air compared to the smaller ones at the same rpm.
Assuming you're able to fit the larger fans in place of the smaller ones, you should see an improvement in temps.
Not only will 3080Ti be hot by virtue of being 3080Ti, it will also produce so much hot air that all other components in the case will get hot.
Undervolt the 3060ti to something like 975mv on the core around 1750/1850mhz, add +100 to the GPU and +100 (conservative values) to the Mem in afterburner and enjoy a cooler 3060ti with similiar if not more performance depending on your card.
If you dont know what I am on about search for some undervolting guides.
Something you can try first without forking out £'s for a new card. Then if you want get the 3080ti.
