- 7 Sep 2020
Long story short, I can't really delay the purchase any more because I need to return my interim GPU to its owner, as his current GPU is dying. Plus, the prices here are unmistakably back to their mid-June levels, meaning approx. 20% higher than they were in early July. So it looks like the evil GPU market is reverting to its evil ways and bouncing back, and I'd rather not be left without a GPU for a second or third time in vain hopes of outlasting the awful situation.
So, I can buy the cards mentioned in the title.
Links:
https://www.asus.com/Motherboards-Components/Graphics-Cards/TUF-Gaming/TUF-RTX3060TI-O8G-GAMING/
https://www.msi.com/Graphics-Card/GeForce-RTX-3060-Ti-GAMING-Z-TRIO-8G-LHR
https://www.techpowerup.com/review/asus-geforce-rtx-2080-ti-strix-oc/
As far as 3060ti TUF vs Trio is concerned, Trio has a 60MHz higher boost clock and 2x8pin versus TUF's 1x8pin. Both have poor power limits. The 2080ti is slightly faster, draws noticeably more power and has more VRAM (11GB vs 3060ti's 8GB). And apparently also has a poor power limit.
All are from companies. The TUF is from a consumer return in a normal retail shop (normal 24 mo warranty), the Trio is from a used-GPU trader (1 mo unspecified warranty), the 2080ti is from another used-GPU trader (12 mo seller warranty).
I'm inclined to go with the Strix 2080ti because of the extra RAM and slightly faster performance, meaning I could hold off the next upgrade for longer or even play The Witcher 3/Dragon Age 4/Mass Effect 5 when it comes out in 2025 or so, provided the card doesn't die on me by then. However, the card's age is a significant drawback compared to the two 3060tis, especially the TUF.
Between the tis, I suppose the Trio would normally be the (marginally?) better choice, but the TUF is almost unused and with full warranty from a normal retailer and not a used dealer, hence a better choice.
There are some alternatives, but they don't look particularly appealing, coming down to either a weaker card with a better performance-to-cost ratio (tempting, but I'll pass unless the price is a complete steal) or the least overpriced 3070 (less tempting, and I'll pass unless I stumble on a great outlet deal unexpectedly overnight). Realistically speaking, these are the only contenders. If the 2080ti was new, there would be no contest. But since it's not, I'm hesitating.
Links:
