- 22 Dec 2018
I’ve had a system built around an Asus Z370-G board, Intel 9900k cpu, Samsung 970 pro SSD, 64gb Corsair vengeance ram 3,2000. EVGA 750w psu and EVGA RTX 2080 gpu. I’ve had this set up for three years now and quite happy, although realising that I cannot run games on high graphics settings in 4k. But one thing I wish I could find info on is. The case came with three front fans that don’t spin fast and one rear fan high up. I brought a Corsair h80 cpu cooler with is single fan radiator and it comes with its own fan. So I thought, why not use existing fan to suck the air out the radiator and the new one to pull air into the radiator. Is this better. Only other option is to mount radiator and fan onto top of case and use original case fan just to exhaust. My only issue is the fans do speed up a lot when temp is around 60c and takes a while till fans slow down. The cpu is overclocked to 5.1ghz. Did manage it at 5.2ghz but some games would crash. But just browsing net, files worked quite well but cannot get it back at that speed. Are there any good guides for beginners with cooling?
