Zanussi elec double oven ZOD550X door gasket
5 Aug 2013
Shropshire
Ordered a new door gasket today -rang up and made sure it was right one before placing the order - I gave them prod number and serial number and they confirmed the one I was looking at was correct.
Next job was to see how easy it is to remove and here is my first problem - All videos and youtube vids show ovens with clip on rubber gaskets -dead easy but mine looks like the rubber is in a slot and needs to be either fed or poked into groove.
I am probably making a easy job sound like a nightmare job so question is has anyone replaced the rubber gasket on main oven.
Also noticed some small screws - one on each bottom corner and one central along top of gasket.
It probably won't get here till friday so more time to look and check.
Model ZOD550X
Pro 9441711514
serial no 80800059
:confused:
I was hoping he might reply - The door seal came this morning - Wife said don't touch it till you have had your steak and chips tonight.
Thats just her way of saying “eat before you try it, because i know your gonna balls it up and we wont be able to use the oven for a bit”
YEP - A Balls up.
Trust me to buy the one and only Zanussi oven to have the never to be replaced door seal - Bought a new seal and it's identical - Started to remove old one and it just ripped so committed. Managed to get it out as it was stuck in groove with 12 yrs of hot grease. - Cleaned groove and would the new one go on - Not on your life -Who ever designed this pile of **** needs their asses kicked.
Any other cooker the rubber is held on at each corner with a metal tab you turn 90 deg.
The wife is so ****** off (not as much as me) she said leave it and we will buy a new cooker (she means me).
At least they are all the same size so just a case of removing the old and pushing in the new "didn't I say that somewhere else"
Not been a good day today.
Ps - got the seal in place only to find the door is twisted slightly - I have had enough so new oven it is.- 12 yrs use ain't bad
Sorry not been logged in because of the monthly authentication.
@DXP55 yeah that seal is a ball ache. It's either remove front frame or release slightly and feed it round bit by bit, but I think you already know that now.
Door alignment probably due to hinge supports 311 73 93-00 / 3
New oven on order - it's done 12 years so doesn't owe us anything.
Yes it was a real ball ache - without my mate over the road who is all muscle I would never in a million years got that rubber in.
I did say to wife - bet this rubber was put in while putting it together. £23 down the drain.
