- 18 May 2010
Managed to drop with Bulb from £167pm to £145, kind of regret it now though and might put it back up to keep this winters bills a bit lower
I mainly just fit baxi 600 open therm boilers with any open therm thermostat. if you turn down the thermostat on your boiler based on the weather outside and up if its snowing you'll not see much of a difference but a huge amount of the population just dont. The open therm is a fix for that as well as not over heating your home like an ON OFF thermostat will.so turning down your boiler temp and leaving it on thermostat at 25c ?? would be nearly the same thing ?i know not quiet .. but that's the way I've done it for yrs ..may look into this as boiler is 10+ yrs old it's a Worchester and slightly over-sized for the house.. got any links plz ?
I've got a Vaillant system using weather compensation and load compensating. It's very good it varies the flow temperature depending on outside temp and inside set point. So it runs long and low and keeps a very steady temperature in the house while unless under about -5c always condensing. It's also allows the flow temp to heat the hot water cylinder to be set higher.
I was limited to over sizing the radiators by 50% due to 10mm microbore pipework but still allows flow temps around 40c on the heating side.
Vaillant's system is called e-bus you can get a opentherm box that converts opentherm to e-bus but never felt the need I may go this route if the Vaillant controls/outside temp sensor fails.
I need to replace my boiler soon as it's a 25 year old system with separate boiler etc.
Is there a significant advantage to oversizing the radiators?
Can I ask what kit you actually installed on the boiler? I have a Vailant and really want to add weather comp to it, but Vailant’s £300+ kit doesn’t make it appealing.
Lower flow temp and lower flow rate = lower energy consumption.
None of mine are foamed in, only overlapped with the external render which still shows daylight in places. Cavities aren't closed in the window recesses either, just wood nailed over. How did you use the expanding adhesive foam? I guess you had to remove the window to install it?In spring when we had the storms I resealed around the double glazed window and found that it wasn’t foamed in at all, only fixed. I used some adhesive expanding foam and resealed as a quick fix.
This might give you a pointer for what can be done https://readinguk.org/draughtbusters/basic-techniques/walls-and-windows/I had the window board off internally and when the wind was gusting could feel a draft from the gap between the wall and plasterboard. There are two vents on the pitched roof quite high up but I guess it also gets air in from under the gutter, and the boards are just dot and dabbed, not fully across the width of the board so air can go down.
The best sound way to tackle energy crisis is to see if you can install some solar panels. At least during spring and summer and early autumn, you get benefits of saving a lot of energyIf you need something to help get in tight spaces with a sealant gun, these angled tips are great 'Wolfcraft Angled Cartridge Tip'.
A real basic one this, boiling a kettle vs using a gas hob to boil, which in should be cheaper. From what information i have found, gas hob should be quite a bit cheaper right now, on the standard variable tariff.
If your gas heats your water, is it more efficient to put hot water in your electric kettle, so the kettle boils faster (using less electric?)The biggest improvement will be only boiling what you need.
Gas hob efficiency is pretty low due to wasted heat around the sides / edges. Kettles are basically 100% efficient as element is sitting in the water.
We do only boil what we need currently but its more a timing thing, 3 different morning and afternoon schedules trying to align the cuppa timing sounds like its probably going to be the best solution. Although my sister in law (who works from our house as my wife and her are childminders) is very clueless as to the cost of these things and has much less care for what gets used in our house. TV's left on, kettle boiled adhoc, lights left on, microwave used, etc, etc.The biggest improvement will be only boiling what you need.
Add to the mix a teenage daughter and you can imagine me and my wife spend a lot of time turning stuff off behind others!!!
We only flipped on to the standard tariff yesterday and managed to get through the day on £3, not that cost is an issue, its just an exercise in being as efficient as possible. Come winter im dreading the added cost of heating!
Thanks those look helpful. Wish they did the same for expanding foam guns - I've been using fish tank hose + jubilee clips to seal overhead in the eaves, but the small diameter hose adds friction and the foam doesn't work if it's too long.If you need something to help get in tight spaces with a sealant gun, these angled tips are great 'Wolfcraft Angled Cartridge Tip'.
Boiling 1/4 kettle instead of 3/4 kettle would save much more than switching off a standby LED and a phone charger draws zero when it's plugged into the wall with no phone connected.You're talking pennies though, the best thing to do is to target all of the constant low-draw devices instead e.g. Sky STB, NAS, leaving phone chargers in the wall, high-energy bulbs
