Has anyone with an Alexa device and a Hive heating system noticed any random heating or hot water events occurring out of their programmed Hive schedule?
I'd been having some random calls for hot water out of the schedule and have been checking my system over, thinking it was a wiring fault on a zone valve (stuck contact) or whatever, but I've not found an issue.
I was discussing this with a colleague at work and he tells me that his friend was having similar issues and with them being away from home frequently, their house was being heated unnecessarily. They contacted Hive and when they looked at the logs it appears the calls for heat were coming from Alexa. The solution was to remove the skill from Alexa so it could no longer address the Hive system.
I've not called Hive myself so don't know if it was the cause of my problem but I have removed the Alexa skill anyway as we very rarely used that function anyway.
This is a bit anecdotal I'm sure you'll agree but I thought it worth sharing. If you have both a Hive system and an Alexa device with the Hive skill loaded watch your heating/hot water system for unscheduled calls. With the current cost of energy it's something we could do without.
. Frost protection is quite important as both boilers are in the garage which can get quite cold in the winter.
