Does this keyboard exist
30 Dec 2010
Over here
I have seen close (Logitech G915) but I cannot get what I want exactly.
  • Wireless
  • White (shroud is it called?)
  • Swappable switches
  • UK layout
  • 60/70%
I can compromise on the colour but not it being wireless. I may have to settle for the logitech even though it's aluminium, was hoping for USB-C charging too but cant have it all.
Get a kit or a pre assembled one from China maybe? Seems to be every combination of hot swap and layout available. That would at least get you in the ballpark of features you want, and then see how quality is. At least you can upgrade the switches if you're not happy.
I did consider the China thing, but to be honest I think that might be a step further than I'm prepared to go and will therefore have to compromise on my needs maybe.
Will keep an eye on deathstalker, I have a feeling I tried some low profile reds before and I didn't get on with them for typing because I kept hitting incorrect keys.
This isn't really what I wanted however it is one of the very few wireless out there. I think I could replace the keys with white ones too. Clearly I have to compromise on my requirements and wireless is on thing I dont want to give up.
So it ticks wiress, replaceable switches, size and UK layout. Actually that is pretty much all I wanted bar the colour.
Interestingly, the Deathstalker V2 says 50hr battery and this Corsair one 5.
Although now I'm thinking I'd actually like the arrow keys etc just not the numberpad.
I swear I couldn't find any before, now I've just seen a white one with most the features I want and it's half the price of the Corsair
Looks like the corsair does 2000hz polling wireless or 8000hz usb, prob leads to lower wireless life but you should be able to change it back to 1000. I've been wandering if razer will add the deathstalker to their 4000hz receiver like they did with the viper v2 but that's going to make for really bad battery too :D
