- 25 Mar 2004
- Fareham
Does anyone run just a battery setup and pull down enough energy overnight when it's cheaper to use throughout the day?
We use around 9000kWh a year but the south facing part of our roof isn't big enough to get anywhere near the number of panels needed. I think we could fit 5-6 panels on the main roof and then 2-3 on the garage roof. The north facing part of the rooves could probably fit 15+ annoyingly!
We've discussed it a fair bit here, the main tariffs that support this are EV ones, if you don't have an EV but you wind up on one, there is a chance they could pull it out from under you. What I'm really getting it here, is you should design a system that doesn't just rely on that being the case.
You'd need a lot of battery power at 30kwh per day, which I think you'd potentially find it hard to charge up in the short off-peak tariff rates.
Not sure how fast you could charge at max speed, may depend on the number of batteries and max supply to the house.
9000 kwh is fairly high, have you looked at what is using that much power? that is around a constant 1kw all day long every day on average.
if you're looking at adding solar/battery/EV anyway you may as well consider contacting installers to see what they can do. South/North might in combination do a fair bit, though I think north is the worst for generation. A lot of solar farms are E/W to get flatter/longer generation even if S is better.
