Huawei 5g CPE Pro 2 H122-373
29 Jan 2022
Carnoustie
Does anyone know if you can self select particular bands on this router.
I have recently tried the TCL LinkHub HH500E and that won’t allow it.
Thanks.
i have this device and no, there isnt a way that i can see to select bands,.
How are you finding the device. I have both an EE and THREE sim.
The EE sim i need to reboot on a daily basis because of disconnection issues.
The THREE sim is stable but the speeds have dropped massively over the last 7 weeks. Can't pick up 5g signal anymore for some reason.
can you pick up a 5g signal on another device?
I've read over on ispreview that a firmware update broke 5G connections on some huawei 5g routers.
you could try this:- https://www.ltehmonitor.com/en/?app=1 althought I have had no need to use something like that.
Mine has been dropping out over the past month where if you browse to a site, nothing happens, i get a blank screen, then after a few seconds, the site pops up. That issues has resolved itself, speeds are anything from 200 to 800 down and up to 150 up. I'm on three business (if that makes a difference)
I used to be able to pick up 5g signal and although it was weak i used to get about 400-600mbps (this is with Three and is also the business sim card)
I only recently updated the device to the latest firmware to see if it would force the router to fix my 5g issue but it hasn't :s
I've tried the three sim card in 3 other 5g devices too with no luck which leads me to believe that it's the mast that's the problem but if you know THREE CS. They are rubbish and won't acknowledge there's a problem with that mast.
I thought lteh monitor would help me in terms of finding the best signal but again it's not picking up any 5g! So annoying because it was so good!
What firmware are you on?
Mine updated to 11.02.11 h329sp9c1217
Might it be worth contacting Huawei for a firmware file you can use to downgrade. Not even sure if thats possible but worth a shot.
I've heard Huawei customer support is worse than three. If you can believe that's possible.
There is a new 5G version of the Siretta Snyper due out soon.
My issues started before the latest firmware update but it is now the same as yours.
Maybe it is just the carrier because I'm right on the edge but seems strange that it caught 5g signal only to drop it after 5 months of using it.
