Solar panels and battery - any real world recommendations?
I only have a 2Kw system that is south-east facing. If I had the spare cash, I would get a 4Kw system on the other side of the roof that is south-west facing, so I have both morning and afternoon covered.
Anyone built their own off grid battery setup? Was looking into it to supplement my solar as an AC coupled system is quite expensive and not sure if it would pay for itself even if I get hold off a decent one.
Was looking at getting some 12v 200ah (2.4kWh if my calcs are correct) batteries, a suitably sized inverter and a charge controller plus any associated cabling. Going by my research so far this looks like I could use this in the evenings to power the kit in my room where my PC's are and then charge the batteries during the day when I have excess solar (happy to self monitor that if necessary and turn the charger on when required).
Going to do some more research later but was wondering if anyone here has done such a thing.
Anyone done solar together, I was emailed by Tunbridge Wells council to say they are starting a scheme.
Just had another email from them to say they are going with Home Smart Energy and the package they propose is
Your offer is made up of the following:
Complete solar panel system
£4,055
  • Roof survey
  • Installation
  • 8 panels
  • Inverter
  • Materials and fittings
  • Monitoring tool
  • Extended warranties
  • Insurance-backed guarantee
With battery
£2,387
  • Battery storage
  • Battery inverter
  • Installation
  • All cabling and mounting materials
  • In-home monitoring
  • Guarantees and warranties
  • Onsite survey (if advised by installer)
Price seems ok to me but they want £150 before 13th May without even coming out to see site with the caveat *Subject to installer capacity.
Did you go-ahead with this @Mr.Cookie? My quote has come through for solar together (central bedfordshire) and I have to decide soon. My quote is £2.5k more than yours for 10 panels but that might be explained by the extra demand.
So is that basically £9k? What is the panel wattage, and battery capacity? You can get a 4kW PV system with a 4.8kWh of batteries for that quite easily.
No I excluded the battery as we're not considering that at the moment as we can't afford it right now
Personal package breakdown​
£6,510​
Your offer is made up of the following:​
Complete solar panel system​
£6,510​
  • Roof survey
  • Installation
  • 10 panels
  • Inverter
  • Monitoring tool
£6,510​
£6,510​
  • Roof survey
  • Installation
  • 10 panels
  • Inverter
  • Monitoring tool
FWIW my quote under Solar Together Buckinghamshire was about 60% more than I paid going outside of the scheme. Ensure you get other quotes if you haven’t already.
I went to, but due to demand they had exceeded their quota.
Deposit paid. Install should happen in the next month or so.
15x panels
3.6+ inverter
Cabling
Install inc scaffold
2* 5.2kwh wall mount batteries
Disconnect cable in place for 3rd battery (will be floor mounted 9.5kwh)
3* additional panels if they can fit for total 18* panels (£600 extra)
£12379 + circa £3600 + installation for 9.5kwh unit.
Total between £16k and £16.5k inc VAT.
6kwh - 7.2kwh system with 20kwh batteries (which I’ll top up with seasonality using “Go”.)
I’m hoping to be pretty much none reliant once I ditch the gas and go air source.
In the mean time I’m getting an AC unit that can also heat to cover the office during the day so I can leave the house cold until it’s needed.
Battery cycles shouldn’t exceed 180x annually if the maths works out (an approx) so there’s no reason why they shouldn’t last 10-15 years before they need looking at again at which point I’ll just stick £50 a month back during this time and replace as and when.
@Andrew Moore Not only will it clip what the panels can produce, it will also limit how quickly you can charge the batteries from off peak in the winter - you may not be able to fully charge 20kwh of batteries during the off peak period. You need a bigger inverter which will require a G99 application.
PS. Also check the maximum charge rate of the batteries.
