- 20 Jul 2009
- Midlands
I shouldn’t need to charge them fully, the max I have used between 4pm and 00:30 is 13.8kwh. If I factor that in, I’ll only need to charge at around 2kwh to keep 16+ in the battery. I’ll never go beyond what is produced during the day even in the winter on a 7.2kwh system and in the summer I’ll have more power and storage than I’ll ever likely use as I’ll not use the battery pack to charge the car I shouldn’t imagine as it’ll be on an 1-1.2kwh trickle during the day@Andrew Moore Not only will it clip what the panels can produce, it will also limit how quickly you can charge the batteries from off peak in the winter - you may not be able to fully charge 20kwh of batteries during the off peak period. You need a bigger inverter which will require a G99 application.
PS. Also check the maximum charge rate of the batteries.
