Man of Honour
- 21 Nov 2004
@Manbatius just did the same. Not difficult to switch on when needed and don’t need the clock. Two microwaves switched off. I wonder whether it’s worth having the cooker/oven left on?
I wonder how much less energy we’ll use as a country now everyone is thinking about this. It soon adds up.
I’ve done this with our boiler. No point heating water to just mix it with cold water. We do have a tank, but it still doesn’t need to be as high.
If you have a Combi boiler you can set the hot water quite low, it should help a little with energy usage. As the water isn't being stored there's no risk from the lower temperature unlike a tank. Ours is set to 45C on the boiler and its ideal for what we use it for, which is pretty much just the bath or shower. Saves on mixing it down so much.
