Man of Honour
- 11 Dec 2002
- Darkest Norfolk
With the Agile tarrif are you able to automate in some way? Guess it depends on your setup to some degree, but don't know if theres any link available...
Check carefully about export tariffs. For instance with Octopus, if you’re on Octopus Go then there are some export tariffs which won’t be available to you.I'll worry about it if we start getting power cuts I guess. It's not a super high priority item though.
With my current SMETS1 situation, and the fact that I'm not sure I can get onto Bulb EV tariff (definitely can't without smart meter working - they won't replace it), I'm instead considering switching to Agile. I think with Octopus the electric kwh cap is 55p/kwh on Agile, which isn't much worse than cap pricing.
The export pricing is uncapped though, and it's possible I could arbitrage energy with the right luck.
Besides that though, I think battery and inverter are Agile aware, so could charge on cheaper times, and export rates for Agile export are good for any excess generation, with prices capped for 12 months I think, this sort of makes sense as a hedge?
I've not looked much into it, but in settings you can set timed charge and timed export, so don't think it's too difficult, but you'd need to go in each day to do it.I believe my Givenergy system will be Agile aware, it will know when the prices are down and can use that to charge for less (I think!).
Of course prices aren't down very much right now, but if the new cap in October is near enough the 55p/kwh on Octopus, then it doesn't need to dip much to make it worth charging.
Not sure to what extent I can control when it does stuff though.
With the prices being so near to the cap variable anyway come start of October, it's not a big deal either way for me.
I'll go on Agile import/export initially, may look to see if I can get onto Go at some point but depends how many hoops I'd have to go through.
If nothing else I'll get paid better for generation than any regular SEG ones pay me, and import should be capped reasonably for the next 12 months I think.
I actually called them up and they're switching me over, Bulb has no exit fees so no barrier to leaving them to switch![]()
are you getting the 9.5kwh battery? If so they have unlimited charge/discharge warranty don't they?I would only do it when it made sense, as battery wear and tear etc will be a thing.
You get prices in the day ahead so perhaps if I get a really good price on a day I could just look at doing it.
As you mentioned though not looked into it much myself either!
In any event, I think Octopus do the best smart tariffs and even without an EV, they are potentially the most likely to do something with load balancing and solar batteries.
Wow, Project Solar UK really are dumb.
My system they installed in 2017 isn't producing correctly.
Trying to cost up the best repair, they have a call out fee £325 which they say covers any repair, but they seem to be reluctant to talk about going on the roof. I don't think the £325 will cover that, but they won't say. They didn't use scaffolding to install, eventhough they charged me for it, but I know they'll want it for this, because they can make more money.
I sent them the daily kWh made for the last month and it's well down.
I sent them a daily output graph, showing 2kw max, on a 4kw system.
I sent them a string voltage output over the day, showing up to 100v lower on one string.
They are saying it's just shading, which I countered it's full sun at midday. Why is there 100v difference on the string still.
They said do a 7 day meter read, erm...you have that data already.
Then I said about going up on the roof and they asked me what I actually want them to do....as to them there is no fault? Wt*....really.....
I don't really want them round my house lol.
Now I'm looking at getting a local company round, which I've been talking too, but they don't use Tigo, so they aren't certified by Tigo to remove them and that invalidates the warranty. Or find a company that is....
So maybe I'll have to just buy new, but if the Tigos have failed, do I want to keep them, will this continue to happen, but it could be panels...
I don't know till someone goes up there.
Urgh....what to do....
Hope that all makes sense
Is that project solar?Good luck with this,..... Its taken over a month to get anyone out to one of my systems, but they are here tomorrow, be a new inverter I bet.
No solar from it for over a month!.
Best to price in a new inverter every 10 years on any installs.
My inverter seems ok, it definitely looks like panels or tigo boxes.
Luckily in the install paperwork I found the electric company that sighed off the install,
got in contact with them (60 miles away) and they are here tomorrow.
I guess I'll phone the local company back and maybe some others.
I just need someone willing to just go have a look, maybe a cable has come unplugged a bit or a tigo box fallen off the panel, not sure how they are installed and kept in place. YouTube time!
I wouldn't mind spending £1k but if it started being more, it'll be very annoying and pointless.
I've swapped the strings on the inverter and the voltage difference follows.
I've also checked the strings open circuit and it checks out the same.
There is def a voltage difference in the strings and inverter appears ok.
If open circuit the strings were matched, I'd be looking at the inverter.
| AT STC) | ||
| Maximum power Pmax | 333 | Wp |
| Open circuit voltage Voc: | 65.3 | V |
| Short circuit current Isc | 6.46 | A |
| Maximum power point voltage Vmpp: | 54.7 | V |
| Maximum power point current Impp: | 6.09 | A |
| Module Efficiency | 20.4 | % |
