Sound cutting out in game
30 Sep 2015
Anglesey
Hello everyone,
I have been scratching my head for the last 24 hours leaving me a nice bald spot....i cannot figure this out.
Yesterday my new MSI 3070ti arrived, my previous gpu died so installed it, installed drivers and away i go however when in game, tried on both Tarkov and RDR2 my audio in game cuts out for literally a split second then comes back, this happens every 20 to 30 seconds consistently and i know this sounds like a small issue but its frustrating.
Ive tried clean install of drivers and ive ensured all cables in correctly.
My audio set up is a GOXLR mini and my headphones are USB, all audio routed through the GOXLR which previously worked fine, the audio on desktop with music or videos has no issues, this is specifically happening when in game.
Any suggestions would be very welcomed
Did you disconnect the GOXLR, uninstall the drivers for the GOXLR,then restart pc, then connect GOXLR with then the drivers?
I will try this and get back with the results.
I didnt know RTX voice was a thing in honesty, i will google how to turn this off. Thank you.
ok mate, if this and RTX voice doesn't sort it. I'd do what I suggested above but before connecting the GOXLR with then the drivers - uninstall the graphics drivers first,restart pc then reinstall them and then restart pc and then...connect GOXLR with then the drivers.
