Hi forum.
I recently bought an LG no frost refrigerator and I find its noise very annoying.
Mainly a constant high-pitched sound, similar to the coil whine of PC components, which is present almost constantly since it turns on every 15 minutes.
It also makes a pretty loud sound when the compressor starts to run hard (when the walls get hot).
And here my doubt, assuming that it is a normal noise, is it recommended that you change it for a Cyclic refrigerator? are they quieter?
Thanks!!!
Thanks!!!
