3070 what a faff!
23 Jul 2022
Dorchester UK
My Inno3D Nvidia GeForce RTX 3070 twin x2 had poor application of thermal paste from the factory, so took it apart and repasted it. Then my memory was overheating, upon inspection I had torn one of the thermal pads. I then ordered some Thermal Grizzly Minus 8 1mm and 0.5mm to cover my bases.
I tried the 1mm first and they were too thick, trying the 0.5mm my memory was overheating due to minimal contact on the pads. I had bought 2x strips of each thickness, so took the remaining 1mm pad and used an old round bottle with no embossing to compress the pad to 0.7mm (which I had read is the correct thickness), finally after more than a few attempts to get the card reassembled with the pads it was working properly. For all my efforts, I was rewarded with a 5C drop in core temps, was it really all worth the faff and worry it caused me, am not too sure.
Perhaps not worth the effort or cost, with potential risks, for that gain. But it has offered you some experience and also serves as a reminder, duly noted, that some things might be best being left after all :)
You'd think for the price they charge they could do a proper job with the thermal contact and not skimp or have trained monkeys applying them
So are the thermal issues recent or the seller not tell you. If not then its proberly been mined to an inch of its life. :p
