It's not the switch using power but the bulbs being "off" while still receiving power. They need this to be able to listen for signals to turn on though.I have the philips hue bulbs in 4 rooms altogether. using 5 builbs. I have the dimmer switch connected to them with a cover over the mains switch. The mains switch is always on. How much electric would this be using when my lights are not even on?
Assuming 0.2W per-bulb just for convenience, that's 8.76kWh over the year, or £4.56 at the new price cap rate.It's not the switch using power but the bulbs being "off" while still receiving power. They need this to be able to listen for signals to turn on though.
It's not much - 0.3W per bulb or less.
I've got a Hue LED strip light - I measured it when it was 'off' and didn't even register 0.1 Watts on my power meter in that standby mode.I have the philips hue bulbs in 4 rooms altogether. using 5 builbs. I have the dimmer switch connected to them with a cover over the mains switch. The mains switch is always on. How much electric would this be using when my lights are not even on?
Gas hob at my old house, the cleaning alone is good enough reason to not have oneI'm far too lazy.
On a kitchen revamp I'd go induction just because of the cleaning!
How long does a fix last in this case?I just fixed my price with UW, they are offering electricity for 61.2p and gas for 14.1
Not bad given the cap is 52/15p respectively
Which other services did you have to take to get their fixed rate for energy?I just fixed my price with UW, they are offering electricity for 61.2p and gas for 14.1
For the past few days I've been doing measurements using a plug-in electricity meter with our Beko washing machine...
Total power used for the entire wash cycle:
At 60C: 1.087kWh
At 40C: 0.543kWh
At 30C: 0.251kWh
So in our case a 30C wash used about half the power of a 40C wash.
I usually wash at 40c thinking it wouldn't cost a lot more than at 30c. But I think I'll be washing at 30c in future.
We do everything on quick wash at 20c, which takes 31 min, gets everything clean and I work outside doing various things that involve coming home dirty.Just seen something interesting in reddit, someone measured their washing machine power consumption at different temps. I'm actually very surprised at the difference between 30c and 40c.
Source
Very useful, I'd be interested in the data during winter. Right now water coming in is probably 15+ degrees - wonder if the numbers close up when it's closer to 10 or below?Just seen something interesting in reddit, someone measured their washing machine power consumption at different temps. I'm actually very surprised at the difference between 30c and 40c.
Source
Source
Surely the comparative difference in winter will be the exact same?So it's a delta T of 15 Vs 25 degrees C & energy consumption will be roughly proportional to that increase. The comparative difference will be less in the depths of winter when the mains water temp is lower.
