That is irrelevant for me though. I will upgrade again anyways because I will do a full system update rather than CPU or GPU separate.Fastest theoretical performance at 720p means that the cpu will last you longer, since it wont be bottlenecking your future graphics card at the resolution you are currently playing at. Say 2 cpus are similar at 1440p but one 30% faster in 720p so..
And honestly all this testing when it has come to 720p gaming, lets say a 9900k compared to the 3800x, the 9900k averaged about 15% faster in gaming with an RTX2080 at 1080p high settings, it still sits similar 15% faster with an RTX3080. It isn't suddenly the 3800x become more of a bottleneck between that GPU upgrade. The % change is within margin of error in real world gaming scenarios.
I have always had people say but at 720p it was X% faster but nothing has really shown any real world data for that being a huge case when it comes to upgrading the GPU two or three generations and one CPU particularly falling off a cliff worse than the other.
Meaning that if the AMD 7600x is 5% faster in gaming to the 12900k with a 6950xt then I expect it would only be around 5% faster come the 7950xt or whatever approx. Could there be a bigger difference if you kept same CPU but upgraded 3-4 generations of GPU, maybe but by then normally new DDR and PCIE options etc are about meaning a full upgrade anyways.
Indeed if it does really come to that close and within 5-10% gaming (I expect Intel to have the lead slightly) then I think AMD would be better option if you was building a new system at moment and able to drop in a Zen5 3D cache chip come Q423/Q124.oh wow so close if thats the case and building new system will go AMD socket support will be longer nice option to have openwonder what can be done with PBO looking forward to seeing it played with
