5700XT to NVIDIA
8 Oct 2019
Greetings to everyone! I would like to change my Radeon Sapphire Nitro+ 5700 XT to something better from NVIDIA since I'm a bit tired of multiple spontaneous issues with AMD drivers from time to time. My config is following:
- MSI B450 TOMAHAWK MAX
- Ryzen 5 3600 under Scythe Mugen 5
- Radeon Sapphire Nitro+ 5700 XT 8gb GDDR6
- G.Skill Trident Z RGB 2*8gb
- Sabrent 1TB Rocket NVMe PCIe M.2
- EVGA SuperNOVA G3 80 Plus Gold 650W
Used for gaming mostly on 2K 165hz Dell monitor. I don't really need high-end beast, I just want to switch to NVIDIA with minimum replacements (like only gpu or gpu+cpu) and some kind of reasonable upgrade with nice price-value.
Thanks in advance!
The 3060 isn't really an upgrade, 3060 Ti is definitely better, but still a bit meh unless you can do it for a fairly low cost. 3070 Ti and up, much better, but you would begin to have an underpowered psu according to what nvidia suggest.
You can get a 3070 non-Ti for about £500 and that would be about 60% faster than the 5700xt.
A 650 watt psu is what Nvidia recommend so your covered there.
I would probably wait for the new RTX 4000 cards to come out and then bag a used 3000 series if you want good bang for the buck. Won't be too long now.
Isnt it only the top end 4*** series being released this year?
