Hello all!
So, as the title says, had a rather interesting experience a few days ago.
Had some time off last week, came back from hols after being away about 4 days or so, as is normal I kill the power to most things in the house whilst away(I assume this is normal!), anyway, Friday AM I spend a bit of time on the pc, nothing intensive at all, playing a few games and watching some netflix after, nothing too exciting.
Wife and I decide to go do weekly shop, so I power down PC and only a couple of minutes later whilst I am getting ready (maybe 5-10 mins absolute max), my wife yells through from the hallway that she can smell a metal burning smell, as I made my way through, I could also smell it (kind of like a soldering type burnt electronics smell). Not knowing where it was coming from, I immediately went through to our main circuit breaker in the hallway (as this was closest to me at the time) - checked it and it looked and smelled just fine so to speak. As soon as I went into our study room (where my gaming PC is located and this was the next closest room) I instantly realised the smell was getting stronger and must be coming from there. I quickly checked the peripherals such as the monitors and other plugged-in electronics before noticing that my actual PC case was almost glowing slightly blueish white near the bottom of the case (as there is a see-through side panel on the PC case).
As soon as I opened the side panel to investigate, I could smell and see the issue was originating from the power supply unit within the PC, worryingly I could also at this stage hear some faint crackling (assumedly as the capacitors were popping and burning away within the PSU) and what can only be described as hearing a strong "electrical current" like something out of a movie about Tesla coils so to speak. I instantly removed the power cable from the PC and moved the entire unit away from other valuables in the room as there are multiple monitors, sound bars etc.
Anyway, with that background out of the way, the question I have now is what on earth could have caused this?
The PC was completely shut down, sits elevated on my desk (still had power connected ofc) but the only things drawing power at the time would have been the actual Mobo rgb lights that stay on when the PC is off and I was charging a Logitech wireless headset via a USB slot on the Mobo itself. The PSU was plugged into a surge protector (admittedly this surge protector is quite old, probably about 5-6 years old) Specs for PC below:
CPU: Ryzen 5900x, 1 year old,
GPU: ASUS Rog STRIX AMD 6800XT LC OC 16Gb, 1 year old
MOBO: Asus Rog Crosshair VIII HERO Wi-Fi X570, 1.5 years old
NVE Drives: 2x Samsung 970 EVO Plus 1TB drives, 1 to 1.5 years old
SATA Drives: 2x Samsung 1TB Evo SSD, 3 years old
HDD’s – 2x Seagate barracuda 10000rpm drives, probably 5-6 years old
AIO Cooler: Corsair Hydro H150i PRO RGB 360mm, 3.5 – 4 years old
RAM: G.Skill Trident Z RGB 32GB (4x8GB) DDR4 3200MHz Quad channel kit, 3.5 years old
Wireless card: Asus PCE-AC88 Dual Band AC3100 PCIe adapter, 3.5 years old
PSU: Corsair HX1000I 1000W PSU, initially bought 7 years ago, however had a replacement one under warranty sent out in December 2020
Case: Corsair 900D Case, 7 years old
Unfortunately, the majority of the above listed parts are now "written off" so to speak, have a few spare mobo's and a PSU from previous builds so was able to test the main components and the casualty list is pretty much everything - aside from the Wireless card, 1 of the 4 Ram sticks and the case. Also, before anyone asks or perhaps assuming some nasty overclock business, there was no overclock configured to this system, never has been and has been running stock since I put it together after upgrading the CPU, Mobo and GPU last year.
Really hoping someone can help me understand what possibly could have happened?
