Trying to buy a pc for £550 that can run Microsoft Flight Sim
4 Sep 2022
hull
I have a budget of around £550 and trying to find one that is in the range is quite difficult, Can anyone help me with this problem
What are you hoping to be able to do with this PC? You have an incredibly tight budget so I am hoping that is not including things like monitor and peripherals.
Thankfully thats not including peripherals or a monitor, Im looking mainly run stuff like microsoft flight simulator 2020 and some other game likes csgo and others.
MS flight sim is one of the most system intensive games you can possibly imagine. You need an excellent PC to be able to run that well so I am afraid your budget does not allow that, CSGO on the other hand is a very easy game to run so you can run that on integrated graphics.
How about on minimum specs It can probably fit in i'd imagine.
The problem with your budget is that you cannot fit a GPU in and still be able to buy new.
If you were to get this -
My basket at OcUK:
Total: £454.25 (includes delivery: £12.30)​
This can run CSGO ok with the igpu, you will not be getting 300+ fps but it will run. I very much doubt this will run MSFS to an acceptable level without a gpu.
If you were to then add a gpu -
Then you can run MSFS just not at high settings. AMD cards are not the best for MSFS but this is the lowest end gpu I will recommend. The 6500 6400 and NV 3500 are not very good gpus. Other than the 6600 or better you can look for a second hands gpu such as 1660 1070 1080 RX570 but even these will push you over your budget
Your budget is not enough to buy new and to run MSFS.
Forum rules prevent us from naming potential competitors.
Came in to suggest the same.
Can be picked up for like £350 second hand now too, probably better than any pc you'll get for £500~.
CSGO will play nicely on a £500 PC but not MSFS 2020. Xbox Series X is a console on steroids so yeah, a second hand one would be great.
I like the 12100 rig that Haz123 put together but MSFM really needs pairing with a 3080 or something strong which pushes the price up to double OPs budget.
True I have a way higher budget now of about 700 but still might be a bit bad but can probably run it now.
So you don't have access to the second hand section of the site but you could still pick up second hand goods elsewhere.
Suggest minimum a 6 core 12 thread CPU, 32gigs of RAM and a 3070 (or AMD equivalent).
You could probably get a second hand build with those specs in your budget (especially with RAM being so cheap and the market flooded with ex mining GPUs) but you'd have to hunt for one.
Personally I think you need a better CPU than any that have been suggested so far. Also, I’ve seen FS use more than 16GB of RAM.
It’s good value but MSFM will still dominate it.
Looks like 1080p 60fps will be doable at medium settings and 16gb ram seems fine with the reduced settings.
