Not exactly, it's a 580 on 12nm instead of 14, so with a minor node revision which enables higher clocks.590 is an overclocked 580...which in itself is a rebranded 480
The tim can be an issue after a year, it can dry out and crack very quickly, plus they dont use the best TIM either. so 3 years yes the tim is dried out and cracked.
That seems like high fan speed for the temps, it should be targetting 75c AFAIK.I just recently bought a used RX 570. At stock settings… this card was running hot (into the 80C’s at times) and fan speed touching the 3,000 RPM range.
After taking it apart, I notice the thermal paste was dry and hard. After a fresh application of whatever thermal paste I had… Temps are now in the 60C’s and the fan speed will only touch the 2,000 RPM range occasionally.
So yeah, so most likely the thermal paste has dried up in your card.
Very nice! Is it underclocking itself with that power limit? Is it more/less stable now? What's the power draw now vs before?-1% power did the trick, max temp now is 67c.
I don't know honestly, I'll turn on the monitor on afterburner and see. I'm starting to suspect the card had a tad too much factory overclock...Very nice! Is it underclocking itself with that power limit? Is it more/less stable now? What's the power draw now vs before?
