1250 budget including OS
Firstly can you wait a couple of weeks for release of AM5? It may not be the best for your budget but there has been significant price cuts on Ryzen 3 chips in other markets so it may happen in the UK as well.
Alternatives.
My basket at OcUK:
Total: £1,232.10 (includes delivery: £13.20)​
I have a set of the ram you chose upstairs and it did not play well with Ryzen so alternative above. Get a decent branded psu , the 650w above is enough but you can get Bequiet 700w for £85, its worth spending the extra tenner imho. GPU is excellent value , good performance:price ratio. Case is personal choice but I think that Kolink one you chose is glass fronted so airflow to front fans is very very restricted, not a massive problem for the relatively low power components you have chosen but it is poorly designed. Like I said above I am expecting price cuts on Ryzen 3 chips ( cannot be certain of them ) but the 5700x is almost identical to the 5800x so you may as well save £20.
Alternatives.
My basket at OcUK:
Thanks for the heads up on the psu! Your basket looks great so I’ll go with that
I’m starting an intense masters degree so I’d rather buy and build it sooner rather than later even if I lose out on value of the processer, cheers.
