Card to replace a AMD Ryzen 5 3400G
27 Jul 2022
UK
Looking to add a discrete GPU to supplement a AMD Ryzen 5 3400G. Motherboard is a Gigabyte A320M-S2H so wary I don’t buy a card which would be wasted on a PCIE 3 board.
Was thinking a 1650 but would appreciate thoughts on wether this is a worthwhile upgrade or if there’s a better alternative.
Have a look here for your current graphics, which is the RX Vega 11 (Integrated) and then you can compare versus current cards and older models that you may be able to pick up second hand
A 1650 or above would be a noticeable upgrade, as would older cards such as 1060 6GB, GTX 980, as well as older AMD cards such as RX570/RX480/RX580/RX590.
That’s an incredible useful link. Thanks for that, I must admit my head is absolutely battered comparing various GPUs
You should be fine with a 1650 but that psu is awful, its cost £20 new its probablly the first thing i would change along with the gpu you decide.
yes I agree. The PC was originally built about 3 years ago to play Roblox and Minecraft. It’s now moved onto Hitman, Red Dead and the like.
That’s good to know about RAM, I was totally oblivious to that. I’ll probably go with then 1650. Perhaps a super if I can source one (and a better PSU). Will be building a second PC for (10 year old) as an Xmas present so will be interesting to see how the 1650 works out.
PSU is 250W for 12v. The processor and mobo wont use much, but I don't think I'd risk more than a 125W 2nd hand 1060 on it. I'd probably down power the 1060 from the standard 125 as well.
Think I am going to replace the PSU at the same time to be on the safe side
If you can keep your eyes open for a good yet cheap second hand one, you'll do well.
Something like a Corsair TX650 watt PSU made in the recent couple of years goes for nothing second hand and will last you a good couple years of upgrades.
