Hello looking for some help with an issue I seem to be having. Firstly a few specs for this PC:
Ryzen 3600 cooled via a custom water loop shared by a GTX 980TI (OC to 1450 Mhz)
Aorus x570 pro wifi pro ITX motherboard
Hyperx ddr4 ram at 3200
RM750 PSU
Now I had this set up in another case however wanted to downsize to ITX. On that board (Asus B450) had no issue with getting the PBO to work. Happily get 4.45ghz on some of the cores. Went with the X570 Auros ITX for the new build because it was at a good price and bit of an upgrade.
With this set up however even if i put the PPT,TDC and EDC to max (did this just to out right prove it wasn't working, did start just tweaking the settings) the CPU still seems to be locked at 4.1ghz. I have tried though Ryzen master, through the bios via manual settings and motherboard setting with no luck. I have a feeling i'm missing something very simple.
Below is the mothboard setting on Ryzen master when running some load:
And this is all the 3 settings cranked up:
Basically no matter what i do in Ryzen master or the bios under AMD overclocking the PBO just doesn't seem to be running and the CPU keeps to 4.1 Ghz.
I did use CTR 2.1 which worked great with some very good clocks with single core getting to 4.8Ghz and all core just shy of 4.4 Ghz. Issue was some games kept crashing when using this in the background so had to scratch that.
Can also get the CPU to 4.3 Ghz just by using the multipler and tweaking a couple of other settings.
Just seeing if someone would be able to direct me where to look. I think I am missing something very simple haha.
Thanks for the help.
RM750 PSU
Google Photos
Home for all your photos and videos, automatically organized and easy to share.
photos.google.com
Google Photos
photos.google.com
