GeForce GPUs are slowing down in Games after installing the Windows 11 2022 Update
Caporegime
8 Sep 2006
On Ocuk
GeForce GPUs are slowing down after installing the Windows 11 2022 Update
Also
NVIDIA GeForce Experience 3.26 BETA Now Available With RTX 40 Series Support
NVIDIA has updated the GeForce Experience software to version 3.26 BETA, offering support for the upcoming GeForce RTX 40 series. The company has also rolled out a fix for stuttering after the recent Windows 11 22H2 update or sluggish operating systems while using the GeForce Experience software
It was an nvidia issue with GFE, they fixed it within a couple of days, no reason not to get on with the update.
Installed Windows 11 two weeks ago on my 3900x / 32GB Ram / 3070 FE system. Not had any issues until I updated to 22H2. The issue as listed is with the geforce experience, which I use for quick convenience to record small gaming clips. The beta driver wasn't available at the time I downloaded the update, so I had to rollback. Once the geforce drivers are updated properly, I will have no issue moving to 22H2. Some nice features I'm wanting on this update "Alt tabbing between windows" will have a much higher contrast, so you actually know which tab is currently selected. Plus Task Menu dark mode :)m
Is GFE still considered a buggy mess? Haven’t used it in a few years!
It's been fine for ages. I use it to record games and screenshots and obviously the stats in the corner for monitoring system usage etc.
