I think this could use own thread.
There's really something new/unusual going in response times:
tftcentral.co.uk
Response times and overshoots being pretty much constant at different refresh rates just don't fit into variable overdrive.
That should show as clear slowing down of response time from decrease in overdrive pulse strength when refresh rate decreases.
Like shown in Asus PG32UQX review.
So I wonder if overdrive has been "decoupled" from frame refresh and overdrive is applied for say 5ms duration...
Followed by pixel's control signal value being changed to correspond to what input signal asked for rest of the frame's duration.
Applying fixed level of overdrive for fixed duration would result in such constant behaviour.
And would solve all too familiar "overdrive good for low Hz is hopelessly slow for fast Hz/overdrive good for high Hz is unusable overshooting at low Hz" problem at once.
Certainly additional processing power requirements for panel controller shouldn't be slightest issue with today's IC manufacturing.
And with 300+ Hz LCD monitors I guess communication speed/bandwidth need between controller and LCD matrix is solvable.
Scope shots would have told far more about this peculiar behaviour.
Cooler Master GM27-FQS ARGB review - TFTCentral
The latest 27" gaming screen from Cooler Master with a 27" 1440p Fast IPS panel, 165Hz refresh rate. FreeSync Premium and USB-C connectivity
