We've got a gas hob above an electric oven which appears to be on a shared sockets circuit, looking to replace the gas hob above with an induction hob. I know I'll need a new circuit as induction hobs need a lot of juice and I've got a spare slot/way, but I'm not sure how the logistics work.
I know know I need a gas engineer to come round and cap off the gas supply and then an electrician to fit the new circuit but how does the rest happen.
- Is the gas engineer going to know how to remove the current hob? My suspicion is at least part of the oven is going to need to come out as there's no visible mounting hardware at the top.
 - Is the electrician going to know how to fit the induction hob, if necessary removing the oven again?
 - How can I be sure that there's enough space below or that the hob will fit in the hole? Do I just do my best with measurements and assume they're either pretty standard or that the electrician can trim it out? Or do I have the hob removed before even booking the electrician or should I involve some kind of kitchen fitter also?
 and as you've said only needs a 3 amp supply circa 700 watts, a good induction will be 7,200 watts plus so will likely need a new supply, we recommend that are on there own RCD as they can cause nuisance tripping if on a split load.
