Yeah I'm also getting some plastic toothpicks and some alcohol wipes.Use a hair dryer on low setting, it will soften the glue to too help to remove the label.
Yeah it's simply to that the stickers are of the same quality as happy meal toys (probably worse).Oh hey saw your post on r/AMD as well.
Unfortunately you're not the only one: https://www.reddit.com/r/Amd/comments/xq9puc/asrock_x670e_steel_legend_coming_to_me_with_a/
Is it just ASRock doing it?
 I know, they chuck a manual in it's all in there isn't it.Why did the use a sticker at all? Just put a blummin’ card in the box.
Not true they make very good motherboards, some of the most reliable ones I have ever experienced over the many years, a sticker mistake has nothing to do with how good their boards are or being a poor company ( I personally have had great support from them if I needed it and they always came threw), just a poor sticker choice or the sticker manufacturer needs the blame.This is why I avoid AsRock.
Not the best company.
Buildzoid often complains about them as a company.Not true they make very good motherboards, some of the most reliable ones I have ever experienced over the many years, a sticker mistake has nothing to do with how good their boards are or being a poor company ( I personally have had great support from them if I needed it and they always came threw), just a poor sticker choice or the sticker manufacturer needs the blame.
				Good news, ASRock is now offering to replace boards with a replacement with the already updated BIOS, so no longer needs the sticker: https://www.asrock.com/news/index.us.asp?iD=5000
Why? I used 3 generations of it's mother boards and have no issues at allThis is why I avoid AsRock.
Ah yes, why didn't you say? I can always rely on one persons experience to get a whole picture of a company's business practices and approach to products.Why? I used 3 generations of it's mother boards and have no issues at all
				Apart from really spotty compatibility with PCIE 4.0 riser cables I never had a problem with my Aqua X570 either.Owned the X570 Aqua, probably the best board I have owned. There formula boards take some beating also, the hate they get is funny.
