First PC build in 16 years, components ok?
£100 difference with the 3070ti fe and 3080 fe, worth it you think?
Is the difference in performance worth it between the 3070 and 3070ti?
see the relative performance chart here: https://www.techpowerup.com/gpu-specs/geforce-rtx-3070.c3674
imho:
3070 -> 3070ti: not worth the difference (1.2x the cost for 1.1x the performance)
3070ti -> 3080: worth the difference (1.2x the cost for 1.2x the performance)
3070 -> 3080: worth the difference, but now into the realms of diminishing returns but still definitely worth it (1.4x the cost for 1.3x the performance)
So I'd be better with the 3070 or the 3080 then and best avoiding the 3070ti?
yes. the only reason why i suggested to buy the 3070ti FE is that the 3070FE and 3080FE weren't available yesterday and the 3070ti FE is the same price of the AIB 3070
now that there are 3070FE and 3080FE available, these are the obvious choices
which one you want to get is up to you
I've not been able to afford to build a PC in years but now have the money. Last gaming PC was built when HL2 came out, lol.
Have specd up a possible PC just wondering if it sounds OK and what your thoughts are. Anything I should change out? I have a Windows key and monitor already. 1440p.
YOUR ORDER​
close
1 X Intel Core i5-12600K 3.70GHz (Alder Lake) Socket LGA1700 Processor - Retail - £329.99
SKU
: CP-69X-IN
1 X Gigabyte Z690 Aorus Elite AX - Intel Z690 DDR5 ATX Motherboard - £279.95
SKU
: MB-5A4-GI
1 X Kingston HyperX Fury Beast RGB 32GB (2x16GB) DDR4 PC4-28800C18 3600MHz Dual Channel Kit - £158.98
SKU
: MY-29B-KS
1 X Samsung 980 Pro 1TB M.2 2280 PCI-e 4.0 x4 NVMe Solid State Drive - £128.99
SKU
: HD-248-SA
1 X Samsung 1TB 870 QVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-77Q1T0BW) - £79.99
SKU
: HD-243-SA
1 X Inno3D GeForce RTX 3060 Twin X2 LHR 12GB GDDR6 PCI-Express Graphics Card - £389.99
SKU
: GX-07V-IN
1 X be quiet! Straight Power 11 650W 80 Plus Gold Modular Power Supply - £94.99
SKU
: CA-128-BQ
1 X Lian Li Lancool II Mesh C RGB Midi-Tower Case - Black - £110.00
SKU
: CA-79S-LL
1 X Noctua NH-D15S Chromax Black CPU cooler - 140mm - £99.94
SKU
: HS-03R-NC
1 X Noctua NT-H2 Thermal Paste (3.5g) - £11.00
SKU
: TH-001-NC
Grand Total: £1,697.92
Thanks
I think your mother board is a total overkill for this system,unless you're planning to upgrade the GPU soon-ish.
for a RTx3060,playing 1440p i5 12400 + B660 makes more sense.
You can save another £11, noctua coolers have a small tube of thermal paste in them.
After all the helpful advice I've opted for a Gigabyte B660M GAMING X AX DDR4 Intel Motherboard with an i5 12500 and a 3070 with 32GB DDR4 RAM. I've shaved about 450 off the price I originally posted by changing some components and buying from elsewhere.
