Can anyone find me this towel radiator in brass?
20 Oct 2002
London
That's not stupid money, that is. Anything like this with the white column rad in the middle, and tall with two rungs for two towels :confused:
There doesn't seem to be many about with a brass/antique brass finish to match the rest of our bathroom stuff? Preferably under 500mm wide as I'm not sure that will quite fit either. Sorry, you can only browse so many of these online shops without going stir crazy :o
Yikes. My girlfriend was balking at £350 let alone £800 or £2000 :p
There must be cheaper ones somewhere! There’s absolutely tons in chrome :(
@Scam
A quick google for vintage style towel radiator white or traditional style towel radiator white brought up loads of options.... the two above are about as cheap as you'll get and under 500mm wide, they're about a metre tall. If you want the taller option it's the 300+ ones I'm afraid.
edit: ignore links, you want brass....they're chrome ones
things work in strange ways - the improved exchange rate will reduce their (imported) price.
I'll raise you
I have ladder style, ... you can get a couple of towels close to the heat, but either of the towel rail styles arguably less efficient than a long conventional radiator, with rack, for a families worth of towels.
