- 12 Feb 2014
- Somewhere Only We Know
As the title suggests, im a bit confused about curve optimiser on my 5950x, I instantly set -15 per core across the board and instantly failed prime95 small fft's, even with curve optimiser disabled I was failing, so i ditched prime 95 and started using various other tests like intel burn in test which i know tests avx, and also 3 different versions of cinebench, i started the tests at -10 and passed everything, so now apart from 2 cores, everything is passing at -15 including prime95, ive still yet to adjust the other 2 cores......go figure ?????
my PPt is at 250 and using 232w according to hwinfo
my edc is at 170 and using 170
my tdc is at 165 and using 155 according to hwinfo
earlier on I was using a guide on youtube were he pretty much ramped all of these upto 500, could that of caused instability ?
