Man of Honour
- 5 Jun 2003
- Falling...
Hi all,
As a bit of a "home lab" I set up an vmware server (the free licence). I have a few virtual machines working on it now that have become a really useful and daily piece of home infrastructure. I have a max of 4 VMs running on it, more often 3.
However I'm finding maintenance and "administering" it a bit complex (and I don't have the time really). Everything on it is backed up regularly so not worried about the data, it's just the ease of use I'm concerned about. It's "crashed" a handful of times in a few years, and managed to recover it, but it wasn't particularly "fun"
It's running on a T320 with 32Gb of RAM. Probably a bit of overkill. However I was trying to find a more simple way to put less of a beast of a pc in the house. I'm even considering something like a synology DS1821+ (I have a synology NAS) as I love the OS and it seems fairly simple to run, and you can even virtualise on it. However it might not be potent enough?
I also wonder if HyperV is more simple? Or if there's something else I should be looking at. I'm trying to reduce my power usage, and the T320 is a bit of a beast.
The simple answer could be - if it works just leave it. The applications I have running are a mail server (not a true mail server, it downloads from the name provider in bulk and then stores all the emails in IMAP so that I have the same email structure across the house and when I'm out). I have a file server (running OMV). And then a windows box that does stuff like newsgroups, downloads, and other similar apps. The 4th one is a linux box that I play with from time to time.
I have a separate machine that runs plex server (it's a reasonably powerful PC so that it can transcode if needed) but that stays off and comes on, on demand.
I have also a CCTV storage server, but I tend to leave that off and rely on the SD cards in the cameras and turn on the server when I go away on holiday.
The "dream" scenario would be to run CCTV, Plex Server and the other machines on it, but not sure if the T320 is powerful enough to transcode? The existing synology could be split into different storage volumes, e.g. media, cctv, home server or store some of it on the server's array of discs instead. Also if I were to put everything into ESxi, I'd be nervous about the ability to maintain it as I'm an amateur not a pro.
Thanks for reading and keen to hear thoughts / ideas.
