- 30 Oct 2014
- Norfolk
So, I just finished building my first ITX built with 280mm fans.
The 3 pin is plugged into the 4 pin cpu header.
I’ve downloaded the CAM software but can’t find anywhere to slow it down even with changing the profiles. It shows the temperature and speed of the CPU though.
The 2 fans are plugged into the fan controller that is integrated in the case.
Anyone have any clue?
Motherboard gigabyte b550i AORUS pro ax
Case - Lian li q58
Case - Lian li q58
