Man of Honour
- 23 Mar 2011
- West Side
12400/12400f would be my choice unless you get a 5600/5600x cheaper.
I went for the Asus B660M-Plus as it was £80 cheaper than those z690 boards and had everything I needFor motherboard I'd look at the MSI Z690 Pro-A or Asus PRIME Z690-P D4, can't really go wrong with either and no need really to spend more for gaming.
don't think that's correct.B660 board will support intel's next generation processors.124000/12400F
5600/5600X
AMD system over Intel for me as the AM4 has the 5800X3D which can be a good insocket upgrade down the line.
Both Intel and AMD systems based on the above are EoL platforms if future upgrades is what you want as well thus suggest the AMD
Bios updates will support RL on B660 but the B660 is still dead the same as AM4don't think that's correct.B660 board will support intel's next generation processors.
whereas AMD AM4 is done.58000X3D isn't generational upgrade.
the B550 also supported Zen 3 only after bios update (I was a very early adapter on 5600x on launch day),it's true no DDR5,PCIE5 on B660 but we'll have to wait for the benchmarks before writing it off as useless for 13th gen.Bios updates will support RL on B660 but the B660 is still dead the same as AM4
No DDR5, PCIE5 just the same. Yea you get 13th gen albeit we don’t know actually how well it will be supported but you don’t get any of the generational upgrades as you like to say.
There’s still a but here. If you go RL you can grab a new mobo and get the generational updates once they mature and hopefully cost goes down because those new mobos and ddr 5 gonna be expensive for awhile.
If the OP is gonna stick to alderlake then that’s not the case as you’d still have to update almost the whole system down the line….. which means AM4 Vs alderlake… I’d personally go AM4 and punch for the x3D
12700F or 13700F.I'm not in the UK, so there's not much of a 2nd hand scene where I am and my daughters PC has just died, even "old" stuff, if you can get it, is basically original MSRP and not cheap, no where has AMD 7 series in stock so I've got a choice between AMD 5xxx or Intel 12th gen, I will be overclocking... I've been back and forth between getting a 12400F to tide over until 136/700k would be available as it would drop in the same mobo, or just getting a 12600k/12700k. AMD 5700X and 5800X are also available for around the same prices respectively.
which would you get?
12700F or 13700F.
You can't really overclock the K SKU series that much and it doesn't improve performance that much since Intel has stopped being stingy and giving us just 4 core 8 thread options.
Edit: I see you went for a 12600K.
Fair enough.I checked around the 12600k results and stock its 4.5ghz all core, overclocked it can go to 5.0-5.2 depending on cooling and luck
my 9700k is 4.6 stock and does 5.1 all core OC'd so that's around the same level or even slightly better of an OC
there's no F stock around near me any more and although the shop confirmed they have their 13th stock in already, its at full price so the 12600k still worked out the better cost/perf option I think
You missed where OP said that there aren't any X3D CPUs in his location.5800x3D nothing else comes close to gaming
Its just the crown for price and performance as you be good for 5 years
