Mobo recommendations for AMD 5600x gaming PC
7 Dec 2011
Building a PC based on a 5600x for my lad, so 90% gaming it will be used for then :)
Been a couple of years since I bought mine, whats a decent motherboard to use these days?
Trying to keep costs down to get the PC down to around £900ish (excl graphics card) so want it affordable.
Something like this seems ok?
Or is the 550 range ok ?
This has been the go-to board this gen at a decent price point. Only pre-order now, so you could shop around and find one elsewhere...
I really really wouldn't spend a whole lot on a MOBO for your use case, it's throwing money away. MOBO prices these days are ridiculous, just another scam in the ever-increasing scam that is PC gaming unfortunately.
I'm using an MSI B550 MAG MORTAR WIFI Micro ATX board with a 5950x, so it will be fine with 5600x. Same goes for any other b550 board so save yourself some money :)
Strangely mine is now listed as being end of life... hmm, I know companies are focusing on 7xxx now but they could at least keep making am4 for a couple more years.... might have to pick up a spare board just in case because stocks can only get worse....
Might be replacing it with the max version, they're even releasing a max B660 which hasn't been out long. With B450 it meant having a bios that supported new cpus out of the box, so maybe it is the same here.
For a 5600X you can pretty much use anything, even A520 (though don't, because they are PCI-E 3.0), as long as the VRM isn't made of cardboard. I can see an Asus B550-Plus Prime for under £110 (if you want ATX). Looks like the cheapest OCUK have in stock is the B550M-A for £120. I think the VRM on those is inferior to the more expensive ones you listed, but they'd be fine for a 6 or 8 core.
perhaps but it seems a bit weird to 'replace' an existing sku for am4, just seems like a waste of resources... completely ditching am4 'now' just seems daft as well
