Hey all,
My motherboard is MSI Tomahawk Z690 I have on the board three gen4 M.2 slots and one gen3 M.2.
I have a M.2 installed on the first slot which I plan just for system and software the second empty slot is located right behind my beefy INNO3D 3080TI iChill GPU.
I just ordered a WD Black SN850X purely for games should I remove my GPU and place it underneath or move to the next gen4 slot just below? The board does have built-in heatsink plates and the GPU does put a little pressure on the plate is that okay? will it also affect the heat?
Im not sure this is right but heard it's going to run better on the closest slot to CPU
Thanks
Thanks
