- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
@Raymond Lin I have Zzoomm installed. You are looking for a plastic cover where the pavement meets your property boundary, that is labelled Zzoomm. I would take a photo of the one outside our house, but it's dark - but you are looking for a plastic cover about 3" x 8"
The installers will then run a line from that point to your property. In my case, they took up some block paving on the very edge of the driveway and laid the cable underneath that. What they will do depends upon where the point external to your boundary is, so find that and you can then guess the route the installers will run the cable.
If the property isn't yours, you will need to sign and give permission for the works to start - if it's a rental, as mentioned you will need the way leave sorted.
I can't see a box, there isn't one.
I don't see problems running the cable on the front "garden", it's only gravel anyway, best place is probably tuck it alongside the slabs. underneath some gravel.
