This is trueOn the plus side, we’re beta testing all possible case, cooling and-power combinations before you end up with one!
Most of that is just fear mongering for views from youtubers who should know better.On the plus side, we’re beta testing all possible case, cooling and-power combinations before you end up with one!
Are you going to buy me one?Huh?
They were released yesterday...
It is, it looks to have an adjustment range from -98% to +33% which I'm assuming from what I've seen elsewhere means 600W PCB.Can you check if this has the 600W PCB
yeah its massive, but its the best looking one imo. there are some right shockers in the looks department in the line upjust look at the size of that cooler
Now much space to the side panel with that evil cable adapter?O11D Evo, bought purely to fit the 4090 in.
Are you using cases GPU support thingy?
I ditched my 680X before I got the 4090 as I didn't want remove the front fans as you did.Spent most of the evening getting this beast into my Corsair 680X case, had to remove two of the front fans to get it to fit and move them onto the bottom of the case which is less than ideal.
Anyone recommend another Corsair case? These things are crazy in size, quite surprising when you see it in person. Looks like I'll be flogging this case unfortunately as much as I love it!
It's a shame as that case's rear chamber is great for cable management.
Can people let me know what card you have, and how the coil whine is on these bad boys?
Got my TUF running at 80% PL (355W-ish max) and it runs 60/61c with a 1000rpm with it left at standard curve (Perf mode). V nice and am really impressed! System pretty much silent during gamingSurprisingly tops out at 65c and 1500rpm in all the games and benchmarks I’ve thrown at it so far (and for those who have seen the H710i case with its lack of airflow, you’ll know that’s impressive).
Got my TUF running at 80% PL (355W-ish max) and it runs 60/61c with a 1000rpm with it left at standard curve (Perf mode). V nice and am really impressed! System pretty much silent during gaming![]()
ASUS TUF (non OC version).Can people let me know what card you have, and how the coil whine is on these bad boys?
