Deleted User 298457
Deleted User 298457
Is it cheaper to the whole thing or just partial?Not sure if it's just me but, what's the question?![]()
I'm also not sure!You still got me
I think it could be a lack of coffee
a snap of fixed mech (windows open most of the time so has dusted up since cleanup)
I'd thought mech had been bent , due to swinging open, or unecessary force on closure
I'm also not sure!
Ok to reiterate what the question is -Can anyone do the maths for me on powerline network plugs? I've grabbed some PoE cameras but I have held off buying a PoE switch so I am running an adaptor + 2 powerline plugs (1 each side).
Do you chaps reckon these powerline networking plugs cost a fortune to run? As if I pull my finger out I can fairly quickly dig a small hole and run the cable and power them over PoE.
What is the maths though?One day someone will invent a mechanism where normal simple questions like this will be available to "search for" by simply typing!
And as if by magic the answer will appear in front of you
Until that pointmaybe this would help
AV600 Powerline Starter Kit
The TL-PA4010 KIT transforms your home's existing electrical circuit into a high-speed network—ideal for daily use. No configuration required.www.tp-link.com
Yeah - like how do I convert (I guess) typical usage to $? Is it just 4.26W = 4.26WH? Convert to kWh? And then multiply by unit cost?What do you mean, how much they cost to run?
from here
a bit disappointing - can you send them back ?
Our average real-world speed score for these latest adapters was 105Mbps – miles below the claimed 1,200Mbps but enough to greatly improve on your home network if you rely on standard Wi-Fi. The Netgear adapters reached 102Mbps. The similar Trendnet Powerline 1200 AV2 just pipped it at 110Mbps.
You may well get even faster speeds. It all depends on your home set up, electrical wiring, and whatever else you have plugged in. to the circuit. Battery chargers and microwaves, for example, will ruin your Powerline speeds when switched on.
We have got over 400Mbps with a 1,200Mbps-rated Powerline but in a less realistic situation with the two adapters next to each other on a wall socket. Once separated by a couple of floors and 15 metres or so the envirnmental limiting factors of a house set in. But even at a real-world 100Mbps, Powerline will dramatically improve your download times in the second room.
Tbh I have found to all be pretty "best endeavours". I am using it simply because the outhouse is too far from the main house to quickly run a cable.is high speed still a misnomer too ?
I am gonna have to be that guy and point out WD-40 isn't a particularly good lubricant. It's good for cleaning, and removing water from stuff, but ideally get some proper long lasting lubricant on top which will then coat the parts sufficiently. WD-40 is a bit light and thin so tends to travel and then dry out.Question is for me, is straight to WD40 best or is there something better for cleaning and then use WD40 to relubricate.
I also have wd40 silicon spray, I may try some of that for the end lubrication, as I think its less sticky to attract the dust.
They’re in different locations, one being in the airing cupboard and the other being in a cabin, otherwise I would combine them haha.
I’d say my unraid box is probably around 65w spun down, the rest being a UniFi nvr recording and an 8 port Poe switch with cameras and a wireless ap etc.
I did measure my pfsense box on its own and it idles around 11w with the G4400, quite impressive really!
My hub5 idles at almost 40w, checked after I noticed a visible change on smart meter graphics since using it.
