So my plan without research is to: put some wooden batons across from edge to edge, attached to the breeze. Attach a section of drywall with a screw into the two batons, use dry wall tape around the edge, I'll remove some of the plastering skim from the surrounding area first. Then have a go at skimming the area.
Then attach a piece of skirting board.
We're replacing the carpet in the future, so will but a cut off of something else down in the mean time.
Gas has already been capped off by gas engineer.
