- 2 Sep 2013
So, due to circumstance (motherboard died), it appears I am now in the market to look for a new system. I've been out of the loop with regards to what systems are what and what technologies are currently in a state of change. So would like some advice and/or recommendations on that front if possible.
System will be used for a variety of purposes but primarily gaming these days. Looking to play something like Bladurs Gate 3 at ultra 1440 or 4k (60fps if not higher). On that front I'm guessing that I'm looking at a RTX3070/RX6700 for 1440 or RTX3080/RX6800 for 4K, is that about right? (For refrerence, the dead setup gives around 25-60fps on Ultra 1440) I'm aware that new GPUs are just around the corner so may hold off a tiny moment before progressing on the GPU front. Although the talk that the next gen GPUs sucking more power (more heat generated too I guess?) is not something I'm too keen on, especially since talk has them higher than this gen of cards. Any general thoughts on the GPU front? I'm of the idea that GPU memory capacity is of a fair import a while back, hence the existing 8GB RX580 and preference of the AMD cards with more GPU mem, however if the GPU will be replaced in around 3-6 years anyway for gaming upgrades (and likely have greater capacity at that point), would that even be an issue? (Hence why I'm not overlooking NVidia GPUs either)
I've also just read that AMD are about to (press?) release their next CPU products that'll also be DDR5 updated. So on this front, can I also assume that unless an Intel system is immediately necessary, it would be better to hold out a bit longer to see how those releases go? With regards to capacity of RAM, I'd likely be aiming for capacity over speed (to match dead system as I also do stuff that eats RAM fast, or I use RAMDisks so need the room), unless if anyone has any specific reasons why I should aim for a higher speed memory kit setup given the range of high capacity and speed of RAM (DDR4 or 5) available from OCUK? I think I remember reading that certain AMD system overclocks preferred certain minimum speed memory? Is that right? And would any of the 64GB kit speeds be fine for those? Although, I'm generally not going to attempt any serious overclocks on anything; may attempt undervolts, but that's about it.
I think there's also talk about Resizeable Bar, Direct Storage, etc that can impact on games? What's the word on those? If what I'm reading is right, the Resizeable Bar requires certain (generational) setups only? Whilst Direct Storge is about grabbing some (Gen3/4?) NVMEs? Is there any further info I should be concerned with on that front for those two? And is there anything else that's a recent development that I should take into consideration?
So, in short, need CPU, motherboard, GPU, RAM recommendation.
Budget, lets assume for now £1k to £2k, although technically feasible to extend further, would prefer not too unless necessary (but would like to see any suggestions in case it's feasible and suitable). Not looking to upgrade the system for a while, hence the ability to increase budget if needed (much like the old dead setup, it was around £2k back in 2012/2013 and lasted until the motherboard died just yesterday).
Thanks.
Thanks.
