Agree unless you have a life critical need then you do not need power during the 3hr duration, but life is about choice and people are free to do as they see fit.
We shouldn't even be here allowing this to happen.
Even she spoke of it at 8:51.
Both wife and myself work from home.
Otherwise no, 3 hour power cuts would not bother me. I bought a generator that should power everything we need to work from home.
What about those who WFH? Or devices like fish tanks where a power cut can literally cost you £100s or £1000s?
I work from home full-time, one of the Level 1 outtages would be between 9am - 12pm for me.
Maybe I work for a nicer company, but they wouldn't have a problem if you can't WFH during a planned national powercut for 3hrs.
Also if you need internet access to WFH and you're relying hot-spotting, then you need to hope the mobile networks are prepared as well.
If you're in an office how many normal company premises are set-up for long term working during a powercut, if they have UPS and generators they're there to allow systems to be shut down safely and for people to get out of the buildings.
the fishtank........ 3 hrs you wont need to worry about temperature or your skimmer not working..... water movement may be an issue to keep your 02 levels up and your live rock happy ... if it were me (back in the day i did used to have a twin tank (4.5x2x2 foot marine tank with sump) i would probably look to get a battery operated pump to keep the water flowing but would not worry about spending loads on heating it for the sake of 3 hrs. hell, when i sold my fish set up, i am near cambridge and i sold it to someone on......... isle of man or isle of white - i cant remember which - but either way it was a fair old trek away, AND i had stripped everythign down and put in buckets which must have took at least an hr............ it would definitely have been longer than 3 hrs down time as well as far far more disruptive than just losing power and yet all went fine with no loss of life.What about those who WFH? Or devices like fish tanks where a power cut can literally cost you £100s or £1000s?
I spent 29 years without the Internet, let alone 3 hours.
And guess what? I survived![]()
How are you going to power the street cabinet? Pretty sure they need power.Internet should still work provided you can power your router.
And the company I work for are a bunch of *****.
Paywalled article. TLDR?
How are they in the position considering all the nuclear plants they have?
But BT told TechWeekEurope that the battery in the fibre cabinet is a bespoke battery and is not suitable for other uses, such as a car battery. The fibre cabinet is also designed to be highly secure and the company will be instantly alerted to any tampering.
“Our fibre cabinets do contain a small 12 volt battery which is used to provide a back-up power supply in the event of a network power outage,” BT told TechWeekEurope in a statement. “It is not a ‘car battery’ but is specifically designed to fit into our cabinets and is not something that could be readily adapted to power anything else.”
“All of our cabinets are highly secure and fully alarmed so that if there were any attempted unauthorised entry – we would know immediately,” said BT. “If the battery pack were to be removed the power supply to the cabinet would not be affected.”
The battery in the fibre cabinet acts as a backup power supply in case of mains electrical failure and is thought to provide up to four hours of backup power.
So the cab's should be okay and I would hope most exchanges would have a contingency to a mains outage, but I doubt that's the case for all beyond UPS for surge protection and safe shutdown.Small 12v battery which will last ~4hrs apparantly.
I don't think we will have power cuts. but it's worth knowing what will happen just in caseI find it weird we as a people just accept 'the news' that there will be power outages........if I ran the power companies, id simply plan for them to not happen and make changes to avoid them...........isn't discussing future events as if they will happen all abit odd ?
How about just make sure it doesn't happen?
It's as if they are trying to make electric a rare product to drive up the price or something.
