Deleted User 298457
Deleted User 298457
Hi folks, spent the day trying to make progress on the "dining room" (was the living room I think). After considering lots of other jobs I could be doing, I have decided this is the best place to start... I've cleared it out to the outbuilding, so just my desk and a few other bits in here now.
The main objective was to be able to sort the pipework out for the new column rad I ordered. And then sort out wiring for new plugs. However rolling back soon became a pain, and self-evident I needed to just lift the lot...
Sacrilege to consider cutting these boards as they are uncut 4m boards for the most part, however enough of the floor is patched to make me not feel too guilty.
^ No wonder the telephone didn't work (I jest).
^ Revealed the "original?" hearth.
^ Liveable
^ This is the hallway that has the pipework that feeds the dining room. The retrofit of heating must have been done in the early 1990s. A decision was made to run the pipework on the skirting, annoyingly. It comes down from the roof at this point so I lifted the relatively "new" carpet and discovered the original parquet hall floor. Not worth saving I don't think, but kind of nice.
The plan is to take the 22mm (not visible) into the floor and run it to the dining room rad, and spur off for a new hallway rad, and also plumb in the living room rad.
^ Cross post from networking but this is the rough idea. I've also got some insulation coming from a dodgy bloke on the internet (£42/unit for 2.4m x 1.2m celotax/kingspan).
Watch this space...
^ Liveable
Watch this space...
Lotsa work
