- 25 Mar 2004
- Fareham
I think that is pretty much the crux of it. Don't know if the V2 Givenergy can charge or discharge at more than 2.6KW.
I find for me the most important things are usually the first bits of it though, first few KW of panels are the most useful, first few KWH of the battery the most useful, and the same is true for charge/discharge.
You can't min/max fully on 2.6KW of draw like you can with the Solis, but the cost for the minor usage from the grid seems fairly negligible, and 2.6KW is usually a good enough speed for off-peak charging too.
Another factor might be support? Givenergy I think are a UK company who manufactures in China, but Solis may or may not just be Chinese, so your level of support could differ, although how much that matters I don't know.
