No, this is just how the 3D image looks when viewed as 2D, I used same panel size 1750 x 1150 mm or something similar.Are you mixing panel types? Some of those look fairly squarish when rotated, more so than I would expect.
Yes, this is possible, I could fit another 3 panels in my garage roof
Pretty elegant though and it worked!I like how you went full CAD, I jumped into Excel on mine and went with right side design on this post
Solar panels and battery - any real world recommendations?
Alright I need the brain trust here! Install started today but it's clear that the layout the installers picked won't work, they had three panels stacked horizontally on the left/upper roof, and that is no bueno. I have come up with two core designs that seem to work: Design 1 on the left...forums.overclockers.co.uk
In Excel I used 1 square on the spreadsheet is 1 CM in real life, and then made every square, square, then I was using shenanigans with thick borders and filling in squares, worked surprisingly well and the model was accurate enough.
Yes, I really don't have much clearance at all top and bottom! bit too close for comfort really, but moar panels!
House consumes 5KWh/year, my electric car another 5K and now wife is swapping to electric that will charge during day so I ll be using what I produce. But I also want to future proof in case EV night tariffs seize to exist. Yes, I want a battery at least 10KWHDo consider that more roof locations means more scaffold as well most likely.
What is your energy usage like in general?
Are you considering battery storage?
Yes indeed. Good luck with your installation!Assuming it was me that your are referring to @Vaddoc then they dont use sacffolding so no need to worry there, they use a system a bit like a tower so I guess multiple roofs would be far less of an issue than installers that use an external scaffolder
Just over 2 weeks to go for me now!
Use https://easy-pv.co.uk/home and input your measurements then you can play at adding different mfg panels and inverters etc and get a costing. I have had many quotes some even never brought a tape measure, 1 even did'nt want to go into the roof space, iPhone has an angle meter, also a tape measure function. 1 guy just counted the concrete tiles lol and was totally out of his depth with the 2nd roof that had pin tiles. Another just guessed!!! Most use easy-pv which roughly calculates your roof size I found it better adding your own measurements. When the quotes came in ridiculous prices think the double glazing salesmen have been reborn lolOK
I thought I d post a follow up to my saga trying to get panels installed. It is a jungle out there.
The last installer was adamant my roof can only take 9 panels, others said 10, one said 11. They come and measure for hours and in the end they don't seem to have a clue.
So I thought I d take things in my hands, maybe this post will be useful to others.
First I accurately measured the external dimensions of my house taking into account the projection of the roof out of the walls.
Then I measured the angle of my roof going in the attic
Then I calculated the dimensions of the actual roof, there are easy calculators on the net.
But then I decided to take it all the way and drew the whole roof on CAD. Well, it seems I can actually get 13 panels in the main roof SE and another 4 in the smaller SW. There will be no shade.
I have no idea how panels are installed but I should not be that far off.
17 south panels is not the same as the last quote (9 facing south and another 9 facing North.)
I really would expect that paying north of £14k, this work would be done by the installer.
I do have another quote coming up (many thanks to the forum member recommending his installer), lets hope it will be a sensible one.
I would have never guessed that it was done in Excel, amazing just how many uses Excel can be put to.
One problem I found with Easy PV was you couldn't arrange panels in both landscape and portrait orientation, also an east / west configuration wasn't possible, it was rather lacking in that respect.
Lovely, many thanks!Use https://easy-pv.co.uk/home and input your measurements then you can play at adding different mfg panels and inverters etc and get a costing. I have had many quotes some even never brought a tape measure, 1 even did'nt want to go into the roof space, iPhone has an angle meter, also a tape measure function. 1 guy just counted the concrete tiles lol and was totally out of his depth with the 2nd roof that had pin tiles. Another just guessed!!! Most use easy-pv which roughly calculates your roof size I found it better adding your own measurements. When the quotes came in ridiculous prices think the double glazing salesmen have been reborn lol
Maybe give it another try? I created both my roofs and arranged them in both portrait and landscapeI would have never guessed that it was done in Excel, amazing just how many uses Excel can be put to.
I have some but yours looks like it's trying to grow a forest!![]()
