Hosted ubiquiti cloud controllers
DHR
DHR
30 Apr 2003
Anyone used one of these that come 'free' with a device? Can you take them back to factory reset after the three years and use your own cloud controller?
Yeah I was thinking the same, presume if you're not monitoring it doesn't need to be up 24/7 either?
If you’re talking about the offer from a place that begins with three Bs then I would bodyswerve it like the plague.
If it goes down you have no control over when it will come back up again.
They don’t run the latest version of the controller and you have no idea when they will upgrade to a newer version. And then beyond that you can’t export your configuration so they’re actively trying to put you off moving away. But it’s your call.
